Any suggestions for Smart Door locks and wall electrical / lamps switches - EU standard ?
M myname70 macrumors 6502a Original poster May 5, 2014 630 81 Jan 15, 2016 #1 Any suggestions for Smart Door locks and wall electrical / lamps switches - EU standard ?
jclo Managing Editor Staff member Dec 7, 2012 1,973 4,308 Jan 15, 2016 #2 myname70 said: Any suggestions for Smart Door locks and wall electrical / lamps switches - EU standard ? Click to expand... Not sure if this is exactly what you're looking for, but the Parce One is an EU standard smart plug. http://www.parce.de/?page_id=1434&lang=en
M myname70 macrumors 6502a Original poster May 5, 2014 630 81 Jan 15, 2016 #3 jclo said: Not sure if this is exactly what you're looking for, but the Parce One is an EU standard smart plug. http://www.parce.de/?page_id=1434&lang=en Click to expand... Thank tou. Re plugs- there are several on the market (I have Elgato Eve ). But cannot see any door locks that can fit EU doors standards. And the wall switches to replace the EU standard lights wall switches ON/OFF
steve knight macrumors 68030 Jan 28, 2009 2,735 7,180 Jan 16, 2016 #4 the locks run off batteries so as long as you can get aa batteries you are good.
