I have a synology NAS in my home network that i shared a few volumes via SMB. I have a macbook pro m1 max that im useing borth in my office room and around in the hose that a switch between wifi and connecting the network apdater via cable.
I have two problems:
1 I switch between wired and wifi on my macbook and SMB-mount seems to not automatic connect via wired connections as long as you have the wifi enabled. Also there is not handover to wired. I set the network adapter on top in my network list. That means i need to disable wifi and reconnect my smb share every time.
2. When a software want to acces smb://myserver/media and that is not connected will not try to autoconnect to the share ( I have saved password and username) on windows even if a letter sux it's still autonnect if its offline
Running ventura on all of my computer and I have a 10G card for the speed
Any sollutions to my problem?
