Even if you have to pay for the battery replacement, isn’t it only $75? Or has it gone up since the last time I had Apple do it?Remember that your iphone is eligible for a free battery replacement when the level go under the 80% within 2years.
I always figured if I have to spend $75 after 2 to 3 years it’s well worth it to get another 2 to 3 years out of the phone. That’s why I just use the phone and plug it in when I can.
Even better, $69.iPhone Battery Service - Apple Support
Need more power? An Apple Store or Authorized Service Provider near you can replace your iPhone battery. See the associated cost by coverage type.support.apple.com
Maybe it was $75 with sakes tax.Even better, $69.
I could’ve sworn that I paid $75 at the Apple store, but I’m getting old and forgetful
Hi sorry for the late post. I'm trying to set up the same automation within the home app but the options I have are "when ppl leave, when ppl arrive and certain time frame". the other two options are greyed out. What should I do so that it responses to the battery level?Maybe it was $75 with sakes tax.
